right ive had this problem for quite a while now and its starting to do my nut in
il try explain whats happning the best i can
first of all ive checked for leeks and none found
the dv is a forge 007p wich it had a sevice last week with the sevice kit from forge so new o-rings all round new piston and plenty of grease
right whats hapning is,and this dos not happen all the time but enuf to piss you off ,so when i boot it and get it on full boost its gos up to 20psi and instead of droping down nicely to lets say 12/13psi it lets go strate away,so it flick strate down to 11psi and it sounds like it half dumps and then it sound like the dv is left slightly open as if it a realy realy long dump,basicly you can hear all the air rushing throuh this is all with my foot on the loud pedal all the time im not leting up at all
any idears....i did think that i mabie need to upgrade to the yellow spring in the 007 but im very unsure
any help would be grate
