Problem with missfiring?
hawtin1584
137
Hey just wondering if any one could help me out at all, i have no idea whats wrong with my car. Its a leon fr and when driving it and you put your foot down the revs build up then when it hits 4-5 revs it starts to judder, like its at its limit or missfiring, its really strange. When i put it in neutral it doesn't do it, only while driving, just wondering if anyone knew of why its doing this and what needs to happen to fix it. Its also been remaped too. thanks to any one that replies.
hawtin1584
137
Also what i forgot to say it makes a funny ticking over sound,which it hasn't done before, only does it when the engine is hot and has been running hard for a while.
rudgey
Mk2 Leon TFSI Sport '06
Jul 2, 2008
286
near Midland VW ;)
Does the CEL flash when it judders? Mine did when it did somthing similar, turned out to be a coil pack, fixed under warranty!
Forgot to ask/say, is yours a petrol? Mine is!
hawtin1584
137
O right ok. If one has gone should i replace them all just in case. How much are they anyway, thanks
DanGB
Who need's a Diesel....
Feb 12, 2006
3,772
London
I never bother, just one at a time. They are about £35 each, but would be replaced under warrenty.
Tam
Santa in disguise :)
Feb 10, 2005
1,777
Near Reevo :)
bad remap ... bad coil pack ... faulty sparkplug .... could be one of many things....
vag com it see what errors it shows. :)
hawtin1584
137
went to the dealer and they put it on vagcom and said nothing came up. I have noticed that the engine light does flash when at the redline. I mentioned the coilpack and they said if it was that it would have showed up on vagcom. Anyother ideas.
clarkeg
110
Armagh, N. Ireland
Did the dealer not do anything about it then? They didn't see any errors on vagcom so done nothing? :blink:
hawtin1584
137
Yea they said if something was wrong it would show up, they said wait till it gets worse and then bring it back in! By then it might be too late or the problem could be a lot more, the car is also smoking alot too.
hawtin1584
137
These are photos of the smoke, just turned my car on and its like this straight away and never goes, was doing this for about 30 minutes, im sure this isn't normal
hawtin1584
137
The emmision light is flashing now! going to get it fixed A.S.A.P, but nothing showing up on vagcom according to the dealers!
clarkeg
110
Armagh, N. Ireland
As you said get it back to the dealers asap, I wouldn't be happy first of all that they let you drive it away even though it was still giving problems and even more so now until you are 100% that the problem has been fixed don't drive the car away.
Clarke
DanGB
Feb 12, 2006
3,772
London
Cant beleive there is no fault codes logged, if the engine comes on there must be.
rudgey
Jul 2, 2008
286
near Midland VW ;)
Weren't in cannock earlier were you hawtin? There was a leon same colour same kit as yours smoking a lot in front of me on the way back from barlows?
Oh just in case you didn't know if the CEL is flashing the ecu has realised that it's misfiring!! Bloody mechanics these days tho....... computer says no!
hawtin1584
137
No wasn't me was in the manchester area this morning. I had the AA out thismorning, thought i would give them a ringas its free and they at least know what they are talking about. He plugged his laptop in and found the error. Cylinder number 1.So hopefully that is the problem, why he found it andseat didn'ti have no idea. Booked in for monday to get that fixed and the alarm, as the alarm isn't working either.
