front wheel bearings!!!
SEATCOOBER
LOVE MY IBEEZA!!!
Mar 11, 2007
1,400
LINCOLN/NORWICH
just had my hub off and took it down to a garage to get new bearing pressed in all looked good and circlips went in fine, i now have a promblem on passenger side that the disc is rubbing on the caliper so its causing a groove on the middle of my disc and since i had this side caliper off,my breaks feel really spongey. Bleed them yesterday and still the same spongey breaks everything was fine till i took the passenger side off for new bearing!!!as id done the drivers side the previous week!!!
ruidos99
a spindle, that how we call it here! you know where the bearing fits in to! do you know where i can get one? or do you have a part number?
ruidos99
hummm its the big part where the bearing fits into , also the strut...
Pingu101
28
are you sure you havent pushed the centre of the bearing out a little. its easily done
if the centre of the bearing isnt supported properley. just an idea for you to look at?
ruidos99
its the Steering Knuckle that needs to be replaced? where can i get one?
