Alloy wheels
benuk
271
UK
yeah looks good :clap:, just make sure you get lower profile tyres to go with it if the alloy is bigger than your current ones to keep the rolling radius the same as now. If you don't your speedo and MPG will be out..
rocky2008
Buy Cheap Buy Twice!
Nov 16, 2008
1,029
North-east
thanks alot mate, not to sure what the profile of the tyres are that are on them at the moment they are round my friends house. also, do you know if the fitting will be the same? they are off a golf gti.
benuk
271
UK
Should be ok.
http://www.tyresave.co.uk/tyresize.html
Check this out to decide what tyres to use, if the new alloy is the same size as the old one you can use the tyres you already have. If different you need new ones.
For example when I bought my car it had 17" alloys and 205/40/17 tyres, however the stock wheel was 16" with 205/45/16 tyres. Using 205/40/17 with 17" alloys kept the total wheel the same size as the new tyres were lower profile.
hope this helps
benuk
271
UK
yes, make sure to double check they are ok before spending any money! Perhaps others here have used this alloy and can comment.
