The bullets are on the radio loom, not the car loom.
Do you literally just pull the two wires out from the block connector and swap them then?
Are you sure you know what you are doing, might be better to get a friend who knows to help or pay someone.
This is the 1st time I have ever been told that you physically need to swap wires over and I haven't actually had the Aura unit out yet.
And yes, I know what I am doing, was just clarifying whether or not the car loom needs to be cut...for me, that's a big no no in any case. I am a neat freak though so i'll just as sooner buy an adapter than swap wires. I rewired my 1st car (106 Gti) because some monkey chopped bits here and there, it worked but the messiness of it all played havoc with my OCD![]()
Lol it's fine, I didn't take it as critisism. Should be an easy job I imagine
By the way, any of you with iPod head units (the ones with the iPod direct connection lead coming from the back, not the Aux port at the front with a headphone - headphone jack lead), where have you fed the wire into the cockpit?
By the way, any of you with iPod head units (the ones with the iPod direct connection lead coming from the back, not the Aux port at the front with a headphone - headphone jack lead), where have you fed the wire into the cockpit? It was easy on the girlfriends Corsa, the facia adaptor was massive with a little cubby hole in it, simple as drilling a hole at the back of the cubby and feeding the wire through.
