Dose this still work if u change ur head unit as the led is in the standered one????
I have tried this...
sit in car - doors closed
1 ignition on to red lights on dash
2 turn off immediately and pull key out
3 hold 1 of the buttons down (dont matter which)
4 PRESS the other 3 times ( with a SLIGHT pause) 1 . 2 . 3
5 watch led on key (should flash) and doors usually try lock/unlock
6 turn ignition key back on to red lights and wait 5 sec
7 key out again and test operation
but at stage 5 the doors do not try and lock/unlock
Can't get my central locking to work remotly
All doors are opened manually with the key, so that works.
can show you on video if you want ?all these turn off then turn back on for so many seconds are bull has it actually worked for anyone because i want to know
you mean stereo ?
not seen a mk2 with a grundig unit in it for about 10 years
you can try it with any mk2 style remote by the way to test it just make sure if you borrow a mates that he codes it back to his car after
awesome pic mate! am i right in thinking that the key splits into key/remote without actually opening it up? I can see how I'd do that with the remote one but not with my non-remote one.
