3inch down pipe
dai cupra
ive orderd my 3inch down pipe and now i heard that they throw up lights on dash can anyone tell me if its true as ive payed for it and waiting for delivery. the pipe has two holes for lamda senssors thanks lads
dai cupra
wot about if u orderd with cat its too late i no just curiouslol
Reuvers
I is a Dutch man!
Oct 30, 2007
3,374
Netherlands
You'll get an engine management light unless its mapped out, like revo stage 2 etc...
I have said this quite a number of times before, but this isn't correct Phil.
As peachy said, IF you do get a code (which I have not seen happen yet, on my car or the other people I know that have one) then you can just weld a nut on top of the lambda hole, and screw the lambda sensor in that so it sits out of the flow.
A Decat will fail your MOT yes, but not give an engine management light
jam666999
Newbie
Mar 2, 2004
269
Northants
Visit site
Im afraid a fair few ppl including myself, have codes thrown up. As mentioned above unless you have Revo Stage 2 you need some sort of spacer. The Wayne angle block is designed so that it screws into the hole for the second the lambda sensor and then the sensor screws into this
Reuvers
I is a Dutch man!
Oct 30, 2007
3,374
Netherlands
I do not hav a map and have driven it fine for over a year. Guess this is one of these things just like how people say the Golf GTI tip causes faults (which I have without codes) and the Golf/TT decat downpipe not fitting (which I also have fitted)
Reuvers
I is a Dutch man!
Oct 30, 2007
3,374
Netherlands
my point exactly ;)
welcome dai. But mind, I'm not saying its not possible to get a code. You might....but then weld a nut like I said.
pj1985
1.8T Power
Oct 31, 2006
2,218
Hampshire/Surrey
Actually this is correct but it is map, ecu and sensor dependant. Seen alot of 1.8ts with decat throw codes for the second lambda.
Dec 3, 2007
2,475
cardiff
i know ppl who have had codes. like rhysox. i dont get code but im on stg2 revo. and rhys is now on custom code st2 custom which he doesnt get a code now
s1l3nc3r
ASBO car.
Jun 30, 2008
1,558
essex
but then you run a cordoba not an ibiza :p
same engine but then so much different. ;)
