cupra not pulling well
tom-cupra
..hello, first sorry for bed english, second i have a problem i drive a 2008 cupra, whit Milltek turboback, Forge CAI, and S3 OEM IC (waiting on remap), when i got milltek the car felt much faster, and the top speed was 270 kmh, a few days ago ther was some strange nois under the car, when i wood flor the car in first ,second, my mehanic discovered thet the milltek was loos in the middle, tomorrow we will fiks it, i think that my milltek is pulling air...the main problem is thet the car dosent fell thet fast anymore, anobady have the same problem.....? please help...and now the top speed is 253 6300 rpm...not good...I dont now is it just the milltek or something else...? And there is now warning light on the dash, everything seems fine....
..here is the problem....
URL=http://s430.photobucket.com/albums/qq26/tom-cupra/?action=view&current=DSC00217-1.jpg]
[/URL]
Chris_Cupra
108
Athens, Greece
You should (or your mechanic) check with vag-com for possible errors ...:shrug: Does the car throw any CEL (check engine light)...???
As I can see from the photo, the exhaust has loosen after the catalyst and 2nd lambda sensor (in the middle section) and is leaking ...;) This can be fixed easily...!!!:)
What kind of remap does your Cupra have on it ...???
Cuprarob112
403
You say the milltek starts at the turbo, so check the downpipe. the Milltek dp is too wide for the space the cupra offers (probably in combination with the engine movement) so most ones fitted in the end will crack.
tom-cupra
..my mechanic and I just welded the pipe, and check ewrything else, the milltek is fine, including the downpipe, the car is going pretty god, I need to check the top speed.... the car dosent throw any CEL (check engine light)....do you recomend thet I do check with WAG-COM, is the WAG-COM the best whay to check if ewerthing is o.k., and can i see the boost presure whit the WAG-COM? How much bar is the standard cupra presure?
..Chris, i will be geting a custom remep,on rolling road, becuse here in Croatia we dont have revo, so ther is no way thet I can get a Revo, or there is? Do you now how?
...and Thank you guys, very much..
Custom-Code HQ
Hi
We can offer fantastic software for the 2.0TFSI coupled with the Autotech fuel pump
With the supporting modifications you have you would be able to see approx 330-350bhp
You would be able to ship us the ECU,have us put the software on then ship the ECU back to you with the uprated fuel pump.
This would come to £748.54 inc VAT + shipping
Hope this helps a little
