How did you did for the lightened flywheel? I'm planning to do on mine, but I have the 1.8 20V non turbo engine. Is it possible?
join the club marc mine black how much were the hid wanna get some
I think I might have to get some HID's soon, Mine are sh1t
Same reason i got mine mate they make such a difference driving at night
DK how easy was your S3 strutt brace to fit im doing mine this weekend
It's not too bad to do mate, Just make sure you have at least 2 of each drill bit'd and start off small
What size bolt's did you get ???
Just makes turn in response slightly sharper and I noticed it handles bumps better.Not sure mate was going to do a search on here i did see some people were using mi10 or something like that.
Did it make a big difference to the handling and did you just do the upper or have you changed the lower brace as well
If you want handling then don't worry about the s3 brace for now and get ARBs or Suspension.
The LCR's have the lower brace already fitted mate.
I used;
6 X M10 bolts 1.5" long with M10 Ny-lock nut's,
6 X m10 washers
You will also need a few SHARP drill bit's
2 X 10mm
2 X 8mm
2 X 6mm
2 X 4mm
Very Nice, must be pretty quick!
