marcb
67
How did you did for the lightened flywheel? I'm planning to do on mine, but I have the 1.8 20V non turbo engine. Is it possible?
im sure you can get a lightened a balanced flywheel for your car i got mine when i had the diff and clutch done best thing would be to contact AMD technic they will point you in the right direction.
marcb
67
Got some new pics with the HID's yesturday
marcb
67
I think I might have to get some HID's soon, Mine are sh1t
Same reason i got mine mate they make such a difference driving at night
DK how easy was your S3 strutt brace to fit im doing mine this weekend
D.K
LCR 225
Oct 24, 2007
6,408
se london
It's not too bad to do mate, Just make sure you have at least 2 of each drill bit'd and start off small ;)
What size bolt's did you get ???
marcb
67
Not sure mate was going to do a search on here i did see some people were using mi10 or something like that.
Did it make a big difference to the handling and did you just do the upper or have you changed the lower brace as well
jonjay
50 Years of 911
Jun 27, 2005
5,843
Essex
Just makes turn in response slightly sharper and I noticed it handles bumps better.
If you want handling then don't worry about the s3 brace for now and get ARBs or Suspension.
marcb
67
They are next on my shopping list but as i have just had the LSD Clutch and short shifter done money is a litte short and as the S3 brace is soo cheap i thought i would get it now
D.K
LCR 225
Oct 24, 2007
6,408
se london
The LCR's have the lower brace already fitted mate.
I used;
6 X M10 bolts 1.5" long with M10 Ny-lock nut's,
6 X m10 washers
You will also need a few SHARP drill bit's
2 X 10mm
2 X 8mm
2 X 6mm
2 X 4mm
marcb
67
I used;
6 X m10 washers
2 X 10mm
2 X 8mm
2 X 6mm
2 X 4mm
Nice one mate where did you get your strut brace from i went int audi at harlod wood yesturday and the twat behind the counter did not know what i was talking aboult and could not find it on the computer.
D.K
LCR 225
Oct 24, 2007
6,408
se london
I got mine from my local Audi dealers.
Here's the part No; · 8L9 805 629 A - Audi S3 upper strut brace
They dont list the bolt's though as they are part of the strutt and the nut's are only M8, You should be able to get them from Homebase or B&Q
marcb
67
nice one DK i have ordered the strut brace should be at Audi by saturday then home to fit it
speedinsaxo
528
Visit site
Did you have Revo stage II before fitting the hybrid k04?
If so do you notice a big improvement over the stock k04?
Who's hybrid is it - Backdraft?
I am toying with the idea of a hybrid turbo set -up, currently running Revo stage II but it only makes 252bhp...
