ive just taken mine off with the charge pipe, the missus isnt happy with them in the kitchen,
Here's some of mine
Function over form
Dave what combination of pipework did you use for the inlet manifold to change the standard pipe?
If you mean the silicon to the inlet manifold, working backward,
straight section
cut down 45
cut down 45
proalloy 90 pipe containing MAP sensor.
ah excellent, you have the PA kit as well, so it will be exactly the same for mine
thanks for that. What size piping?
I don't have a PA intercooler though, mines a Forge LCR single pass. 63mm on the coldside, Jamie.
Looks good loony,
Was thinking of doing the dv relocation, need to go search for more detail on that as i have an ibiza.
