Timing Belt
KikO[PT]
Is time now to change the timing belt on my LCR:cry: do you know how much it will cost me if done on a main dealer??
If I dont do it at main dealer but at a private garage there is any brand that you recomend for the belts??
George
Hi Mate. I'm guessing it will be a silly amount at the stealer.
Kits I know you can pick up quite cheap on the net, have a browse - but my VW mechanic friend told me that apparently if you get the genuine kit from the stealer, although around £100 ish (he hasnt confirmed so may be cheaper), you still get the parts warranty :) which is better than a cheapy one cos obviously you don't want your new belt to snap. Get these parts then you can get a local garage to fit for a much much reduced labour price
Also, while you're at it, get the water pump done too, and put a metal impeller version on as the plastic ones are susceptible to failure.
Linky for water pump http://www.water-pumps.org/Audi-A3-1-8-waterpumps.html
Have a look on that site, you'll need your engine code :thumbup:
Hope that helps
olliep
Wants a mk2 GTI
Oct 3, 2005
709
Winchester
definitely change the water pump at the same time. i have been dealer quoted between 360 and 500 for a change. whats your mileage and age?
bit of a mission from where you are but JKM just your side of portsmouth will do it with vag parts for a tad over 300 and they come well recomended.
George
Fair play cambelt change is expensive lark. My mate quoted me £100 labour and around £100 parts... a good price really, and I'd rather the £100 quid beer money go into his pocket to be honest
