cupra dies and comes back to life
SNOWZ
106
Hereford born and bred
This has happened a couple of time now,
The car drives fine, no ecu light and it just dies, as if its stalled and then about 10 mins later it starts again fine and still with no ecu light on.
Its happened a few times now twice at junctions or at lights when waiting just stalls then wait about 10 mins and also when it was in motion it just died, at the time it was driving normally not racing.
Anyone any ideas???
cordobabrendy
FOOORRREEE!
Aug 24, 2001
7,642
belfast
Sorry I cant help but going by the thread title, Id rename your car Jesus.
Actually, Id be getting vagcom onto the case and failing that, check the cabling and voltage to the ecu.
SNOWZ
106
i call it more than that but cant swear on the forum..
Just looking now to see if i can find anyone local to me to use there vagcom as i haven't got it
SNOWZ
106
I had a problem like this, but it turned out to be a combination of a split boost hose and a dodgy maf, but i would sugest getting it on vagcom
i've replaced all the vacuum pipe with forge ones as they was perished, i dont know about boost pipes but i think i should hear and feel if it was split and shouldnt stop the car or stop me from starting again, as for MAF i was wondering if it could have something to do with it
still waiting for help with vagcom
chrissy1502002
Search Button Ambassador
Jun 12, 2007
343
Portsmouth (ish)
www.bebo.com
yeah depending how big it is you should hear it and almost certainly feel the loss of power, but as i say i had both of the issues, but i beleive that the maf was causing it to stall when idling, but if i gave it any revs, it would be fine
SNOWZ
106
no loss in any power drives smooth, and when it dies its instant and no chance to apply any revs its as if it has an off switch and someone turned it off
Dec 31, 2005
1,856
London
have you made sure that all pipes are tightened, check the turbo to charge pipe hose has a proper jubilee clip on, and all the little ones, even the one off the top of your dump valve has a zip tie on them.
SNOWZ
106
last week i replace all the vacuum pipes for forge silicone ones and ziptied everyone to prevent them falling or forced off.
cant disconnect MAF as it doesnt happen all the time so cant see how that would make a difference, the car runs fine and boosts well haven't noticed any change in performance
Dec 31, 2005
1,856
London
you do need to get it vag com'd
im guessing the speed sensor but think you should go over your pipework and check for kinks or loose connections
SNOWZ
106
why would the speed sensor cut it out when moving and stationary and stop it from startng straight back up?
i'm struggling to find anyone local to me or within traveling distance to help me out with their vagcom
SNOWZ
106
i'm hoping for you its not a new ecu anyways :) just worth a check anyways.
its under the scuttle panel on the driver side if you didn't know
yeah me too the mrs is already complaining about it as it keeps happening to her and she dont trust it anymore else it will be bye bye cupra:(
daza b cupra
135
walsall
mine wouldnt start couple of times left for ten then it would turned out to be crank sensor your,s may not but just sayin
