Hid Zenon Kit fitted <MK1 LCR>
George
Hey mate, looks quality! You're based in Herefordshire? Cool! where abouts? I'm from Leominster :)
Haven't seen your car around but if I do, I'll give you a flash so if you see a Red Leon flashing then you know why haha
Jan 3, 2006
834
East Kilbride
How many of you guys have done your dipped and high beam?
Been thinking of getting some H1's as when i use the high beam its a horrible yellow colour compared to the 6000k HID's Ive got. Having both fitted must light up the dark country roads brilliantly yeah???
cuprakyle
looks awesome, had 10k on my last car, gona do the same to the leon when new years out the way
good work
jwfcms
384
UK Yorkshire
i got the 6k look really ice white but still a bluey colour to them, got to remember the higher colour temperature you go the more light output you lose, its hard to tel from pictures i guess.
everybody normally fits the ballast to the battery cover (not the one which comes off- the battery shroud)
Always hard to find a place to fit the other one. if you remove the washer bottle, two 10mm nuts you will find a place to fit it behind there can squeeze it near the wing and cable tie it all in safely and still use the bracket. out the way and secure.
i think 6k is the standard ones which are in range rovers/bmw etc i havnt seen any 8k or 10k yet. have fitted around 15 of these to different cars and have never had any problems. from the dianne shop ebay.
CupraR_Lad
515
Herefordshire
Yer herefordshire! (ledbury) haha! ok mate i will keep an eye out for you! :p
CupraR_Lad
515
Herefordshire
I'm having another problem,
When switching my sidelights and headlights on,it causes the water temp and fuel gauge to flicker and then turn off!!but then comes back on after about 5secs,i dont think this would be caused by fitting the HID's im sure it was doing it before I fitted them!just didn't notice!
What do you guys think?loose bulbs maybe,loose connection! :( it really gets on my nerves it doesnt even do it when I'm going over bad road or bumps,just seems to do it when it wants!!!
Thanks...
Seat Mike
i fitted my 8k hids yesterday, i took your advice and cable tied one to the water bottle and the other one to the battery casing, it worked a treat lol, they are soo much brighter they are ace, would recommend them to anyone!:)
DannyC87
Rubbing is Racing :-)
Mar 4, 2008
3,459
i've done both, main beam still flashes fine, and have lasted over 6 months now (touch wood) - they take a few seconds to reach full brightness, but once lit they are amazing :) i live in the sticks and don't see too many other cars at night, so my main beam gets alot of use!
Mar 18, 2003
1,249
In oncoming traffic
Visit site
The other thing about 6k hids is that the suns black body radiation ie light is at approx 6k, so your eyes after a couple of millenium have evolved to see well at this spectrum. the reason they look blue and sunlight yellow is that sunlight is scattered by the atmosphere! So the best colours to use are 4.3 and 6k, 4.3 because the hid is most efficient and producing most lumens and 6k cos thats what nature (or god/gods) designed you eye to use! Phew rant off!!!!
dannyFR+tdi
454
St.Helens, Merseyside
fancy getting some main and dipped hid's for mine after getting alloys and coilovers done and was wondering how easy it is to seperate the headlight to clean the lens? i know its a sealed unit but inside the lens is so dirty on mine
Jan 3, 2006
834
East Kilbride
Where did you put your four ballasts mate? I'm gonna get some H1's when pay day comes, should really have asked Santa for them :rolleyes:
DannyC87
Mar 4, 2008
3,459
i've got them mounted in the inner wings, wheels and inner wheel arch off job! very stealth though :)
CupraR_Lad
515
Herefordshire
How long to fit them?? took me about 1hr,and as for drilling all you need is a 25mm drill bit to put a hold in the cover so you can put the bulb through and make a tidy job! :)
big eck
3,976
Falkirk, Scotland
I fitted mine a while ago now and what a superb upgrade for any car.
I went for the 6k ones and I was planning on goin for the high beam ones as well but the low beams are that good at night I dont need them lol
Vin-R
342
Midlands
for an OEM look i stuck to 6k .... more white than blue.... ;) had 8k on all my old mk4 golfs, thought id try 6k this time ... the output of light is more you see than 8k and above .. basically ... the higher you go in "K" ... the less theh light output.
