J.C said:
Phoned Awesome recently to ask about Fsd's with Eibach springs because like a lot of you guys, i wanted to improve the ride and hadling of my lcr but didn't want coilovers. Whilst on the phone i had a weak moment and having previously read Ruddmeister's sticky , along with what others have said, i decided to add a pair of neuspeed antiroll bars to the order.
Sound advice that
Sounds good mate! Same for me, my car is for every day use and im not too much of a mad driver but just want it to handle a bit better. I was thinking 25 front and 28 rear mainly coz that seems to be what most people go for?? but now after reading you little report im thinking your choice sounds about right for me? Oh my god, im all confused again now. You are spot on when you say about the worry of getting the wrong set up as this is not a cheap upgrade. I would like to have it all done in the next month or 2 so still got a bit of time to think. From what you are saying how your car is now i do think it sound pretty much what im looking for. Thanks for the reply mate, it has been a
help, i think?
I think the comfort is mainly determined by the shocks and spring so take the ARB's out of the equation first.
Decide on a budget and if comfort is a priority but with budget considerations the Koni FSD setup sound good for a mix of comfort and lowering etc, if money isn't so much of an issue the Bilstein PSS coilovers were excellent in terms of damping / comfort too. If comfort is less of a consideration or you want more track focus start looking at other coilovers with adjustability (rebound etc etc)
My advice on ARB's is this when you are upgrading the ARB (assuming it's on an LCR) the front is 19mm as standard so 22mm is only a small gain and 25mm makes more sense to me. That big hole in the front of the car (where the engine sits
) does a lot of flexing and I believe 25mm works well. I would recommend a strut brace too. There was an argument the car would understeer with a big front ARB.....I never found this even in the wet.
Rear ARB - TBH I don't think it matters that much 25mm or 28mm (there was a 32mm availabe at one point which would be a bit OTT) maybe personal taste but I dont think you'll **** things up choosing either.
I know it's a lot of money so if you are in doubt start with a strut brace and some ARB's first and do it in stages
