today was frustrating to say the least.
i re-taped the wiring loom and got everything ready to install dash.
i then fitted dash and bolted it up on drivers side.
when i went to bolt up the passenger side the studs behind the dash where 1.5" away. in the right place just too near to the bulkhead. when i dug out the cupra one i had (which i thought i had fitted) i realised they looked the same but sat differently....
so after completly removing the dash along with the fan unit and had re-fitted the correct bracket i was actually worse off than what i was at 9am
i carryed on getting it all back in, bearing in mind in not in the garage due to the kit car and it was p!ssing it down. just before dark i had most of it in and connected. Happy days, starting to feel like a vario cupra now
i tryed the central locking and the buttons seemed to be working....untill i realised i couldnt get out
anyone got any ideas? doorcard is off and i cant unlock it. key from outside does nothing so im abit stuck. i had to get out of back doors as they wernt locked luckily
also, Q for roly. what did you do about the screws/mounts in the ends of the dash? they done line up with the brackets. thanks
heres a pic of dash mostly in...i love it
