Misting rear lights
big green
Hi. I have a constant problem with an 03 ibiza. The rear divers side lamps keep misting up internally. They are a complex contruction. Does anyone know how to open them up without breaking anything so I can dry them out and then seal them?
Crafoo
Crazy Fool!
Apr 30, 2005
5,498
At home
I get the problem on mine, doesn't really bother me much but seeing as my car is booked in at the dealers next friday I will enquire about this "fix", might as well get it sorted if I can.
big green
Thanks for replies. I had a look at the previous threads. lots of moans about the misting but not many solutions. I thought that a misted light was an MOT failure, thats why I am concerned. I have tried putting silica gel packs in the rear but theres no direct way to get into the space between the red plastic assembly and the clear cover. I will look at putting a vent hole in the red section to see if that will work. I think a hot soldering iron would be better than trying to drill flimsy plastic ,its bound to crack. I might also try to dry the units in an oven at low heat and then seal the edges with silicon rubber.
cheers anyway. :shrug:
maddest_cow_eva
Yep I thought it was an MOT failure too hence the reason I kicked up such a fuss about my front lights being in a really bad way. Eventually I managed to get mine changed but the dealer said it's not an MOT failure :confused: And there still not clear all the time but I big improvment. My rears seem to only mist when I clean it.
Best of luck with getting it sorted.
big green
Have sorted problem. I used a soldering iron to make a small hole (6mm) through the rear black cver and then through the red inner linner, making sure to stop before hitting the clear cover. This was done at left bottom and right top of each light. within a few hours all misting had gone. Rained buckets last night and was cold this morning no mist or any moisture detected. Only worry is going to be spiders etc getting through the holes!
hon_n_gem
Candy White K1
Mar 22, 2006
1,132
Kent
www.auto-tuner.co.uk
yeah i would drill a lil hole but i hate spiders wiggling there way into the light. had a little friend in the front light a while ago, still making a campsite of my front light. but after a bit banging on the light it soon left via the back. :D
lukey
4 Ringer
Sep 28, 2006
327
Harrogate
i enquired about steamed headlights at wills and ellis in york, he said bring the car the service dept will look at it for repair or replacement, he said there IS a fix kit for them they need seats permission though, so gotta go bakc with the car for them to evaluate
mark90
83
Why do they fog up extra after washing:(??im obviously missing the obvious?!:cry:
mark90
83
lol...
collected my new mk4 tonight.... :D:D:funk:YES headlights have moisture inside!!:(
on first viewing i could see the inside of headlights looked dusty/dirty(due to past dried out water),
however tonight garage had obviously cleaned the inside,they were clear like brand new....
by time id drove her home moisture was building in along interior botton!??!
Wonder how he cleaned the inside!??lights were far more effective as a result!:confused:
ibiza..fr
headlight
i went to seat with mine at the weekend an dye it is a fault with the headlights.but say they have got to drive it so long with the headlights on and if that fails check the seals on it and then send a pic to seat for them to decide.but they will only hav a look if its got water in not just mist lol mad lol
Tom B
4,710
16
Northampton
I used to have this problem with my offside rear outer cluster, I took a silica gel bag from a shoe box and put it behind the bulb holder. Within hours, the mist was gone and its never returned.
There is a repair for the front headlamps, its on the ELSAWIN system if your dealer plays dumb!
