whos fitted a 150 turbo to a lesser engine?
devonutopia
fabia-lous
Mar 30, 2004
1,200
Exmouth / Exeter
You're not going to have time. Firstly you need the 4 injectors. Then you need someone with expert knowledge of removing & installing PD injectors as it is not a simple unbolt and plug in job. You need to have all the correct bolt torque ratings, and each injector needs setting up on a certain point of the cam rotation (This is where you mentioning the vernier gauge comes in). It's not easy at all. If you get it mapped on the current injectors, see if you can ask them to write you a map for higher fuelling injectors at the same time? They might do it for no extra charge.
brad1
the man has spoken ;)
devonutopia
fabia-lous
Mar 30, 2004
1,200
Exmouth / Exeter
And I have the official manufacturer info for removing/refitting PD injectors units too, so I was able to undertake the fitting of my race injectors myself (with the aid of a couple of mates who run a garage and had all the gear I needed ;))
BIG4244
51
Dartford kent
Maybe i should of added... i work for VW!!! lol oh well atleast you were thoughtful enough to warn me! i know what there like, i wouldnt like to try it without the printouts!!! lol, i need to find some injectors i think, i must say anyway cheers for everyones help so far, devon on tdi club you say i can get a wider intake, is that from the 150 or a custom job, also can i not block the E.G.R. pipe?? cheers
devonutopia
fabia-lous
Mar 30, 2004
1,200
Exmouth / Exeter
Ah yes - working for VW does make it a bit easier! :p
You might fiond your current intake is enough, but on pd130 ibiza/fabia, fitting the cupra ibiza pd160 air snorkel gives better flowing air.
EGR pipe can be capped off yes. Either just slip in a thin sheet of metal to suit ro go the whole hog and get the Allard EGR power pipe which comes with the blanking kit and a sexy EGR replacing pipe.
BIG4244
51
Dartford kent
E.G.Rs already blocked matey and the airbox on the caddys different to the fabia, its like a touran if you know what that looks like! its got a letterbox in the slam panel and a C shaped tube that comes down ito the box, im not after to much power, just ''enough'' to be un-expected!
strugers1
big was you at amd yesterday??if so i was talking to maz about arbs lol
ryanp
What mods to get 170hp??
My bro has a set of PD130 injectors going cheap! along with a PD130 intake and seat sport intercooler setup!
Ryan
ryanp
PM An offer matey! If it does not sell I'll twist his arm and steal it from him for My TDi
