Can I use a golf 4 arm rest metal base?
leon291155
193
I searched all over the forum and i found alot of threads about the armrest but not this question..
if i used the golf mk4 armrest can i use the golf 4 metal base because i cant find the LEON metal base here in my country :( just the golf mk4 base so
Can i use this
instead of this
cause i cant find the last one (Leon one) in my country but alot of golf's armrests with its own metal base..help me
jiege01
Toledo TDI
Jan 11, 2006
236
Magherafelt, NI
i would say it should work. all the bolt holes will be the same, its just the connection to the bottom of the armrest that is different.
leon291155
193
Thx but i need a confirmation .. i dont want to buy it then :cry: ... if anyone know or tried it before plz i want help
Adz87
184
Southampton
yes you can! thats what i have used with my one. the only thing is when i got mine i only had the two bolts cause i couldn't attach it next to the hand break as the bolt is to low. but it'll work fine with just two. i had mine in with two bolts and it was nice and sturdy! but if you have all the right fixings like the nut extension for the hand break bit then thats even better. i've got them all now and it doesn't feel any different then just having 2 bolts.
Adz87
184
Southampton
ok mate no worries. i will have to do it tomorrow evening though i'm working all day but your get some pics. but it will work. so if your gunna buy it then buy it. i'll take some pics tomorrow for you.
Adz87
184
Southampton
right just got home from work. i'll go out and get the pics for you. i'll take pics of the metal base don't worry. give me an hour (i'm slow!)
Adz87
184
Southampton
right here it is with all the right fittings,
so here it is with out the metal base. excuse the mess......
if you only have two bolts to fit it with then it will look like this. there will be a gap between the bolt holding the handbreak down and the metal base. in my pic i don't actually have the bolt that use to be there. well i do but i use it some where else.
Adz87
184
Southampton
the extended bolt you need is this one.....
this is what it looks like when it's on and with the metal base on it.
and this is what it will look like with the base on and the centre console in place
and with the arm rest!
so there you go! hope that helps
if you do use just 2 bolts on the right side its sturdy and it works fine. the other hole actually sits on the other bolt so it holds it in place.
leon291155
193
THXXXXXXXXXXXXX mate for your help..but one last silly question..it seems in the last pic after the armrest is on that the metal base is not covered! ?
Adz87
184
Southampton
thats because i was just showing you what it looked like when it was all together with out the cover. i have them and they're on now. i was just lazy and didn't take a pic of it with the covers on.
leon291155
193
I think this was the most helpful thread about the golf mk4 armrest..i think many guys here will thank you not just me (thx again mate)
