Leak - NOT the door leak, and probably not pollen filter....
Nimzy
177
Yorkshire
If when you open the door you get a gush of water, as if trapped between the door and the frame + puddle in footwell, then this is definitely the door seals. Fix is cheap and simple. If there is water on the bonnet release cable, then possibly something else....
This is exactly what i get on my two front doors, but leaks into the footwell, and mine also comes with two free of charge puddles in the rear footwell that sound as though they are under the carpet but i cant feel any water on the surface??
How do i fix this??? :(
CupraString
407
West Mids
Why can't I
:censored: I know this is a common fault with leons but why can I not find why my drivers side footwell is soaked? I have read the other threads and Im really struggling to find out how to stop it please help if possible.
Nimzy
177
Yorkshire
hey cuprastring ive got the same problem aswell, in the passenger side footwell i can clearly see the water dripping in and im going to follow some of the guides on here but in the drivers side i have no idea where its coming from :confused:
CupraString
407
West Mids
trouble is i can't see it dripping its just full of water and when i hoovered the car today i had two swimmers doing lengths of my footwell
Nimzy
177
Yorkshire
I can hear squelching( i think thats spelt right?) in my rear footwells but cant feel any water on the surface...
anyone got any ideas on wot this could be and how to fix this?
Dave H
87
Perth, Scotland
I have read the following guide twice, but in all honesty it looks simple enough.
My next step is:
http://www.seatcupra.net/forums/showthread.php?t=44216&highlight=leaking+door
using the sealing cord part no. AKD 497 010 04R10
http://forums.vwvortex.com/zerothread?id=961163&page=1
steps 1-23 are helpful
Nimzy
177
Yorkshire
Im going to have to invest in some of that sealing cord, im sure ive seen a part number lurking around somewhere.:banghead2
latics33
Think I sorted the pollen filter leak by following the excellent guide on here, but now have the drivers footwell leak. Placed tissue paper around the drivers footwell, and none of it got damp, but still have a soggy drvers floor carpet! My assumption is that the leak is dripping from the bulkhead directly under the carpet and gathering in the footwell.
What a nightmare it is! Anyone any ideas? I bought the car from a car dealer (not Seat) around 6-8 weeks ago, so this should still be covered right??
ChrisJ
Lemon
Feb 2, 2007
314
APD Vag - Near Holton Heath
As i have said before, not sure if it was this thread or another but you need to seal up the 'electrical box' under the scuttle pannel. You will also need to remove the wiper motor and linkage which is easy and all will be revealed!
wardy2602
128
Stoke-On-Trent
I had all these issues tryed the doors, the fuse box in the end it was the bulkhead.
If your car is still under warranty then any seat dealer will sort it for nowt.
If not I would not like to say how much the rob dogs would charge.
jskelton555
53
staffordshire
waterleak into footwells
http://i359.photobucket.com/albums/oo33/jskelton555/seatleon/seatleonbulkheadhole.jpg
the water on my leon came through a unsealed hole in the bulkhead under the wiper panel, it ran down the back of the carpets/sound deadening and into the footwells on the drivers side. rear footwell is lower than the front footwell so it gathers there to a greater level. you can hear it sqelching under the insulation before you see it.photos attached
you can just see bonnet cable above and edge of wiring cover gasket to the right, any other questions please PM me i have lots more photos that i am trying to upload
thanks
[URL="http://photobucket.com/jskelton555seatleonleaks"][/URL][URL="http://photobucket.com/jskelton555seatleonleaks"][/URL]
jskelton555
53
staffordshire
water leak
hi, just check this link may help:
show bulkhead seam thats not sealed!! lots more photos
latics33
Cheers jskelton555, can you PM me with your e-mail address. I'd like to pick your brains if possible?
Do I need to remove the seal from around the bottom of the windscreen to remove the scuttle panel, and if I do this will the seal just puch back into place once done? Anyone any tips please let me know.
Cheers.
latics33
so do the seals go straight back on around the windscreen once you've put the scuttle panel back? Just don't want to take it off to find I can't get the seals to stick back! Cheers.
