Actually thats pretty poor
Im just looking at a kit on ebay and trying to figure out the wiring.
The ballasts have obviously got the wires that connect to the HID bulbs.
Am I right in assuming that the ballasts will be connected to each other via a wire, then wired to a power source?
On each ballast there looks like there is a port for a plug/wire.
Each side is wired separately.
You have spade connectors that connect to the cars bulb connectors simple push fit, and the plug that feeds the bulbs goes to the ballast, be simple when it's in front of you, just post up if any problems.
Oh Pat I get you. The ballast basically uses the original wiring, converts the charge, then feeds the new wire and HID bulb the converted current.
Am I right?
so basically, the only potential ball ache is getting the H1 bulb to fit the angel eyes
Just checked the box in the garage. Just says ULTRA - Auto Cosmetics
Yeah everything is lined up fine. The lights are all the same height etc. The lens is just blank other than the e mark and a couple of serial numbers
