now you have connected those RCA converters on to the output of the HU...
lets focus on the speaker wire you just cut!!!
you next have to blank off the rear speaker cables (trust me on this please), wrap a bit of tape around them to keep then neat. and make sure they cant short.
next thing you need to do it get your good quality speaker cable and connect it to the front speaker cables. this will enable you to use the stock wiring on the front speakers
. if you dont want to do this then do as i did and run the speaker cables to the speakers then back to the amp in the boot.
right next you have to wire your good quality RCA cables down the drivers side of the car.. i found that wiring the cables under the fuse box, then under the plastic plate that holds the bonnet catch, under the carpet and along the sill. (also wire 2 x decent speaker cable along with the RCA cables)
(PICS)
(PICS)
