yeah i'm gonna get mine from him too. if i go for 5mm on the front will the rear track still be wider than the front?
mate the LCR is 19mm either side wider than the rear....so if you want the rear to be wider you need 200mm and no fronts.....
if you go for the 5mm fronts and 15mm backs then it will be (in theory) 24mm front 15mm back.....
see thread..http://www.seatcupra.net/forums/showthread.php?t=178184&page=2
