Equal length manifold
Feb 1, 2007
1,293
gloucester
you never heard of xs-power manifolds?
crack tastic... but for the price give it a go and let everyone know how long it lasts before cracking on you.
my mate went through 4 of there de cats, eventually gave up, they are guaranteed for life, but last about 3 weeks, and then they keep sending the same product out but just a brand new one, so they crack again and again and again, cracky cracky
cuprabaz
Racing 2020VT
Jun 22, 2004
2,357
Aberdeenshire
Crack aren't a problem if you have welding gear in the garage and coded welder at hand lol.
I've still got one of those ATP like cast manifolds that Adam & Mike imported from Canada or where every they got them from, no cracks in it........yet:)
GarryGti
TurboLag is ur head start
May 1, 2008
338
Skagdover, Hampshire
I also have an ATP manifold which has no cracks on it and seems be go going alright.
Just a little question can you get bigger turbo's that fit onto these minifolds like the GT28RS Eliminator Turbo?? or are they just for Ko3s's. so if that will fit would i have to do any thing else? do you have to increace the diameter of the air intake pipe work to allow more flow?? I think i've got a 2.5 maybe 3' dia exhaust with high flow cat.
I would like put a bigger turbo on then put 440cc injectors and get it remaped to suit at a later date. Is this wise or should i do it all at the same time?
beattie17
1,353
Perth
I dont know, me personally id change injectors. You can easily get a 3bar or swap your 4bar with someone
GarryGti
May 1, 2008
338
I've may have s3 injectors. what bar do they run at with standard fuel pressure regulater and fuel pump? is it all down to the remap what bar they run at??
Jan 8, 2007
2,958
Wiltshire
Dragging up an old thread but just wanted people's opinions on one factor of the JBS tubular collected manifold, as shown here:
As you can see, the header for cylinder 1 is considerably longer than 2, 3 and 4. Would this not cause starvation in cylinder 1 at high loads? As the gases are always going to take the shortest route then this design seems a little questionable that's all.
Thoughts/comments?
