log into engine control module with vagcom and the ecu number is reported top left.
6K0 as std ibiza, 8N0 a possible early S3 equivalent code they'be used in the 512k box
(same as Jabba's base file for IHIs in ibizas)
Its a narrow band tho so it wont give accurate a/f readings as the voltage switches as its only accurate over a small range of AFR around stoich.
Either get a wideband or forget block 031.
its an eliminator. dont they all deliver power like this? (ignoring your timing issues)
Its going to be laggy.
My eliminator v Jonah's GT28RS
:edit: Actually, I don't think it's laggy once it's spooled, it's very responsive at 4k+ rpm.
he had a big spike at 4k, the eliminator isnt that much more laggy, looks smoother though
its the waiting till 4k bit for high 200 low 300bhp ish bit...
If they have good transient responce like you say why are they so slow to get going? They're not that big a turbo after all
that's a bad example dave, his is seriously turned down....
