gtrs eliminator?
DPJ
Dec 13, 2004
7,996
NN Yorks / Salento
www.seatcupra.net
I still don't get the timing. :confused:
Here's a plot of actual timing of 003 - Seatcoober on T2, Mine on T9. You'll see his is way more advanced than mine.
Nov 2, 2004
9,335
South Wales
I'm gonna ditto what someone else has said, is that stage 3 you got installed?
I might dig out an 003 stage 2 log now to see how it compares.
ian_cupra
i've not got vag-com with me today, and i think he was trying to get thursday friday off work to give it back to the garage to sort out
SEATCOOBER
LOVE MY IBEEZA!!!
Mar 11, 2007
1,400
LINCOLN/NORWICH
could not get thursday friday off got coulple of days off next week need to speak to kev really to see why the knock correction has got worse by moving the filter, what needs to be done ian on vag-com!!
ian_cupra
nothing now i dont think mate, not got it today anyway, just give it to garage to sort mate :)
SEATCOOBER
LOVE MY IBEEZA!!!
Mar 11, 2007
1,400
LINCOLN/NORWICH
spoke to kev today and he said the best option was to give it to my tuners to sort out as they have all the gear to do all the checks he still thinks my maf readings are out and this is whats causing my knock correction, now ive got the mbc fitted should sort out the high boost peak then they can get some good intake readings. Kev thought you cant compare mine and daves map as they are two different cars and he said they would not be that close really so thats why my timing is higher, car is going to the tuners on tuesday and wednesday so ill let you know and i might have a healthy dyno chart to show everyone!! fingers crossed!!! lol
Nov 2, 2004
9,335
South Wales
Why have you fitted an MBC, your not gettin a spike at all and its only running 11psi? I cant see how running low boost could have that much effect on your timing. Maybe i'm wrong.
I think you can compare maps, both stage 3, both same spec etc... I think for stage 1 and 2 maps on different cars you cant as cars come with diffeerent turbos, cr's etc...
Personally i think your timing settings are incorrect, as if its running T9 plus lemmiwinks tweaks.
Talking of lemmiwinks, wonder what it would "read" from the ecu?
What are your long term fuel trims? Block 032?
