......is it just the 3" MAF housing that I need and my current MAF goes into this housing? ..
Depends on who is mapping it - you'll need to ask them.
Do you have lamda probe wells in the exhaust/DP?
If you don't you'll need them to map this out during the mapping process.
Are you thinking about engine mounts or Dog bone mounts to control any extra engine movement to allow you to get the power to the wheels better?
good stuff m8 but i would recamend the engine mounts, for 2 reasons 1 to get the power down a little better but most of all to reduce engine rock and stop it pulling away from your downpipe ( some fitters wont give a warrenty with out these or some kind of brace )
Bigger turbine or bigger compressor?![]()
.........Fit modified thrust bearing, fit larger compressor wheel and reprofile to suit.........
turbine is bigger (although will compare before and after pics when I get a chance) ...........
Now thorougly confused.![]()
ok so kill me for not being a complete techie in the continuity of using correct modiificational terms (it's been a long day!)
"compressor wheel" looks bigger is what I meant Dave![]()
We'll let you off as long as you cease causing (me) confusion!![]()
Out of interest, what's the total cost of this so far then Jamie?
I'm going round and round in circles in my head deciding whether the gains you get from the gt2x over the k03s are worth it for the money you have to spend on the whole package (i.e. uprated clutch, injectors etc etc).
(total cost including fitting and mapping)
Mmmmmmmmmmmmmmm Toys!!!!
