Widening the Track + 5 stud
J1MMY
the man with the van
Jun 30, 2005
65
brizzle
Could you not use the toledo flanges pressed into the Ibiza hubs for the fronts? Been looking into this myself, am I way off the mark in thinking that 6k/6k2's are the same in this dept and that toledo's are pretty much just a 5 stud 6k2?
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
not sure on the exact race sizes but if bigger theres a possibility it could be machined to match but then may as well have original redrilled to 5 stud pcd anyway just as easy and will fit in no problems
depends on how much 'extra' width you are after as a wheel 1J (inch) wider is nigh on 25mm and tweaking ET offset could put it pretty close but then thats really not as efficent as a wider track but pretty close
