South Wales Cupras Chat
Status
Not open for further replies.
Forbez
Huge Member!
Feb 11, 2004
5,878
S.Wales
Visit site
I think my first Coil pack has gone, loost boost, and it sounds like i'm driving a cross between a scooby, a harley, and a 3 wheeler! LOL
Cant get the bast@rd last coil off to check it either, though I suspect that this is the faulty one. Grrr.
rhysox
Ibiza Cupra 1.8T
Jun 18, 2007
438
Cardiff
forbez- exactly the same problem as mine! new coilpack arrived this morning from vagparts, hopefully it was that! vag-com said misfire on cylinder 4, moved coilpack to cylinder 1, and then code changed to cylinder 1. so had to assume coilpack! :)
jivejester
336
I got 2 spares if your desperate
Dec 3, 2007
2,475
cardiff
cheers for putting car on vag com mate. just went out and got maf now. will be fitting after i have done the bypass!
thanks again
Dec 3, 2007
2,475
cardiff
just in the middle of it now. having bacon sandwich thanks to nan! i am actually moving everything as well. hidding everything!
rhysox
Ibiza Cupra 1.8T
Jun 18, 2007
438
Cardiff
just fitted my n75j valve and new coilpack. what a difference that valve has made. pulls so much harder now. wasn't expecting it to do that at all! fingers crossed no limp mode! :)
Dec 3, 2007
2,475
cardiff
help. done my bypass and i know it is correct! folowed the pictures to a t! now my car is running like a bag of ****! will not rev past 2500. i had a problem earlier with it starting!
i have however put new pipes on for the fuel line.
anyone think of anything it could be
jivejester
336
check the hose going to the actuator and dump valve are correct
rhys - ill chuck you a pm. im asuming you have everything needed?
o'leary - i want your babies
Status
