Im hopeing it should pass, its a 2003 car and everything is how it should be. The only thing is that the handbrake and rear brakes in general seem weak.
Although since my mum has been using the car for months and months ive not been insured on it. Im insuring it tomorrow for a while though and ill sort out the brakes and then takje it for its MOT next friday hopefully.
Its never had a good long run for ages so it will be getting one at the weekend and my TDi will have a week or so fest
SO im looking forward to getting to drive my 1,0S again
wont work . ive now delt with 3 arosas with this
problem . its the wiper motor itself thats collapsed in on itself . when you take the boot cover off to see the wiper motor there are two tiny little holes on the black plastic mount where the hose goes into the wiper motor . thats where the water is pishing out of . theres no way to block it up and you need to replace the motor .
Just watch out cause all the cars i have fixed that
problem on then 10seconds later developed the
problem of the washer pipe splitting behind the door cards / interior trim in the back
Ah dont say that! Or thats my £30 down the drain!
I went (50) miles to the seat dealer for the fixing kit which should have been intoday. However it wont be in till 3rd of march now as its on back order!
I have taken my motor apart and found that the brass pipe which should be connetcted to the shaft of the wiper and the black jet nozzel has torn off! Which means the water is now coming out of those two small holes you mentioned.
So the kit is supposed to fix this
problem and it comes with a new shaft, jet etc etc.
I did price a new motor but thats like £77 with discount so thats quite a bit and my motor otherwise is pefeect.
So im hopeing it will work.
But if you know for sure that it wont work then please let me know and i will cancel my order and get my money back
Since once i have it i carnt retunr it!
