Alhambra ECO location
Tuningsolutions
Evening all,
Just a quick post.
Does anyone on here know where I can find the main ECU on a S plate Alhambra TDi? On the later models they are behind the battery on their side, but this one I'm looking at I can't find anywhere. Is it possible it could be under the battery tray?
Don't want to start unbolting things for no reason!
Cheers in advance.
saul79
thats where they are on a ford galaxy with the same year so i shouldnt think there different on urs :)
Jun 28, 2001
1,533
personally i'd try behind the instrument cluster.
use a stumpy philips to remove the cowl and youll need a t15 torx security bit to undo the screws. and if youve got a problem with boosting its will be down to the vac pipe split inside the ecu.(thats is youve checked n75 (boost pressure control valve) and airflow meter)
saul79
isnt that only on pd engines
Jun 28, 2001
1,533
pd motor ecu is located next to the battery. i should know i work on the things day in day out!
Jun 28, 2001
1,533
old afn etc engine ecu is located behind cluster and auy pd is next to battery
saul79
and i work on them to in ford galaxys Mate ,didnt say they weren't there ,read original post s-reg isnt a pd ,and highlighted part of your reply was to do with pd.hasnt even mentioned it was to do with boosting etc wanted to know where ecu was located ,thought they where in pass footwell on old shape ,so i was wrong .no big deal
