Custom Code
sharpeyone
Hi All. I purchased a 2005 Seat Leon Cupra R just before Xmas and have been lurkng on here since. Yesterday I had a guy from Custom Code (Jason) come and do a phase 1 remap and it is fantastic! 5th gear now pulls like 3rd, with the power now all the way to 7000RPM. On my previous car, an Audi TT I had Revo and thought that was good until I sampled Custom Code. They are in another league. Also it was a bargain at approx £300.
Willie
LCR Track car
Aug 6, 2004
8,939
Sunny Scotland
Welcome
Glad you made the non REVO move, why did you choose CC over REVO?
What do you think of the LCR compared to the TT?
There is a long running thread about the comparisons between the two and it would be interesting to hear it from the horses mouth
sharpeyone
I choose CC as they have such a good reputation on the forums and the price is a bargain. I have a revo dealer located one minute away but they are charging nearly double what CC charged! Another reason was that the Revo map was very aggressive and nothing over 5500RPM. Also it had a fault where you would upload the map with your SPS box and it would be great for a day and then you could feel the power back off. The only way to get the power back was to reload the map. I have since heard that they try to use too much ignition and the Engine was backing off to save itself.
Points I miss from my TT are: Traction! Traction! Traction! Heated seats, Bose and chocolate biscuits at the stealer!
Bits that are better on the Leon: Definately faster (No 4WD losses and slightly lighter), seats are much more comfortable and supportive, Less common, a bargain in comparision and better feedback from the handling.
andycupra
status subject to change
im glad you are happy, however to clarify that the sps device for revo does not upload the map.
The map is uploaded to the ecu and the sps device allows you to adjust the boost and timing settings of the map. (this allows you to adjust to the fuel being used for example).
If you are uploading a revo map and its then holding back this is most likely do to the settings being too agressive as sometimes less is more. What settings were you using on the sps? other reasons are hot conditions which the 1.8t engine is known to be effected by.
however, it does sound like you ae enjoying your new CC map so thats great news :)
sharpeyone
I had the basic SPS device which had 3 programs, normal, remaped for 95 fuel and remapped for 98 fuel. It was the remap for 98 fuel which I had a problem with. It is the later more expensive SPS boxes that you can change ignition and boost.
andycupra
ok,
what fuel did you run?
it does sound like for whatever reason the ecu was pulling back due to the more aggressive settings on the 98 programme.
APR had a similiar system but via cruise rather than an sps..
Stubbo
56
Stoke on Trent
I was going to have the Revo map but after what you have said i will go for the CC.
Plus i can have a new DV and still not spend the money i would of for the REVO.
caveo
the good thing about cc is that once youve had a few mods you can go phase 2 to really take advantage of them and you get a % dicount .
caveo
yes but im sure hes not going to leave it there after tasting phase1, we never do ,do we?
sharpeyone
It was always run on Optimax. I did try BP97 but was the same.
sebasti0n
81
Just took a peak at the custom code remap prices & they start at £350 + vat for a standard LC 1.8 20v T.... so how did you manage to get it for around £300 ????
sebasti0n
81
ok... yea ... seem to recall reading something on hear about it.... hopefully they will do another discounted offer when I have some dosh.... Xmas what stupid time to have an offer !!! who has got the readies at that time of year.... lol
sebasti0n
81
tempting..... so basically there mobile & come to your doorstep to upload the code ???...
what is there after sales support like, incase you have issues ???
and will they come and reset back if your not happy with the remap ????
lc_allan
Northern Monkey
Sep 15, 2006
3,389
I'm liking the sound of CC more and more now. I think a mobile remap may be on the cards very soon :)
Although not sure which phase is best suited?
Have but not fitted: Forge 007p, Forge TIP.
Purchasing soon: Green Panel Filter (Cold Air Scoop - if it gets off the ground).
Considering: Full BF system
Not sure either if a 4 bar FPR is needed?.
Any recommendations?
CupraCai
Hey Sharpeyone, how have you found your fuel effeciency since the remap? And is the mpg reading given to you on the dashboard still acurate? Do you feel that its worth getting? Cheers:)
