Charge Pressure Maximum Limit Exceeded
truCido
Race Lupo in progress...
Dec 11, 2003
2,938
Bristol
www.vagowners.co.uk
I got this today...I put my old MAF back in and drove it yesterday and all was fine. Driving into work today I wasnt booting it but I was on my way up to 70 and the boost cut out completely. From then on the turbo wasn't spooling up at all and on my gauge wasnt even getting to 0 it was just like I was running without the turbo but I had no warning lights or anything come on.
So I pulled over and checked for errors and got the Mass Air Sensor signal too high intermittent and the below:
17963 - Charge Pressure: Maximum Limit Exceeded
P1555 - 35-10 - - - Intermittent
I'm assuming this is down to the MAF but could someone just verify? Or could it be a dud N75?
Oct 17, 2006
893
Walthamstow
id blame the maf - as it seems to cause most boost issues and cant say ive heard of anyone whos ever had a screwed n75 - unless they have used a race one
Mar 10, 2005
1,439
Walton on Thames
I've got the same problem at the mo, I'm waiting for a N75 to come through the post which I hope will sort it.
although as you've been having MAF issues recently maybe its linked to that...
Does it do it everytime, or just the once?
Dan Cupra R
The Yellow Sub
May 2, 2006
1,514
Reading
I get a similar thing happen on mine. For example im driving on the motorway in 4th gear at 70mph. If I then floor it in 4th (and its always 4th, no other gear) the car will boost normally and then all of a sudden at 4.5k for example it will suddenly feel as if I have hit the limiter and then all boost is gone completely.
I usually then pull over, unplug & then plug back in the MAF sensor and it all comes back. Now, when Ive done vagcom I get Charge Pressure Control - Negative Deviation.
I always get the boost back but it does get frustraiting because it only happens when in 4th and then booting it.
Mar 10, 2005
1,439
Walton on Thames
when I 1st got my k03s etc fitted I got that alot...I had to take my car back to the tuner and he raised the parameters (or something lol)
p34ch3y
tastefully modified
Oct 17, 2005
2,879
cambs
i had this when i got a new n75 valve sent it back to vag parts turned out to be a faulty n75
Dan Cupra R
The Yellow Sub
May 2, 2006
1,514
Reading
is all this with useing that race valve?
No mate, Ive still not fitted the n75 yet, still sitting in its box. This has been an ongoing thing for a while and its been suggested it could be the current n75 valve im using. Havent tried the reace valve yet but will fit it when i can be bothered. Too cold and windy at the mo
p34ch3y
tastefully modified
Oct 17, 2005
2,879
cambs
ive had just the same go on with me for about two weeks and it was a brand new n75 valve from vag parts,,...i sent it back and they tested it for me and told me that yes it is a faulty n75 and sent me a new one and its sorted now no probs at all.......my money is on the n75 for sure
ganda_cupra
VW Commercial Technician
Sep 4, 2006
286
Near Sheffield
I had the exact same thing happening to me when I had a P-torque remap, used to get negative boost deviations everytime I booted in 4th and 5th at around 4800rpm and occasionally did it in 3rd if engine loading was correct. Just used to cut power and only boost to 5psi, would only reset itself out of limp mode when I turned the ignition off and restarted the engine, which was a mega ballache.
Took mine back to will and he couldn't sort it, ended up getting it put back to standard and refunded, then went elsewhere.
Since having it remapped by another company (CC) I've not had any problems, so I know it wasn't a fault with my car causing the underboost, and I still suspect it was the P-torque map. Might be worth a call if it does it everytime you plant it in 4th at around 4500rpm.
Hope it helps.
rhysox
Ibiza Cupra 1.8T
Jun 18, 2007
438
Cardiff
i get this as well, exact same error! not fun when it happens!! hoping it's my n75 too. meeting with phil tomoro night to get it logged, see if we can see any problems. i've got vag-com trial, so i can see the codes, but cant log :(
Mar 10, 2005
1,439
Walton on Thames
fitted my old n75c this morning and its fixed the problem :)
now I just need to get another n75j because the n75c makes my car feel a bit tame
Dan Cupra R
The Yellow Sub
May 2, 2006
1,514
Reading
Hope it helps.
An intresting read. I will try my new n75 first and see how that fairs. If that fails then I will have to do some more investigating. Its not everytime it happens to me but, every now and then say 1 every 3 months it seems to happen to me.
Im hoping it is the n75 valve rather than the map but we'll just have to wait and see. Thanks for the input:)
