someone please help me, im scared
james walker
cooling is the key people
May 24, 2007
5,121
retford notts
heeeelp, driving dopn a1 today, car started stuttering on acceleration, only when pushed foot to floor and a orange light came on the dash, looked in the manual and says something about pollution sensor!
didnt come on and stay on just flashes, and not strait away after a few miles it did, now it drives like a bag of spanners and just judders and generally sounds aweful!
i could bloody cry
help me someone.
p.s leon cupra 20vt 2002:cry::cry:
james walker
May 24, 2007
5,121
retford notts
coil pack failure, you need vag com to see which pot the coils failed on
its in in the morning to be looked at, how much for the coil pack and how long do we reckon guys?
is this a common thing and are the symptoms sounding right for this?
its the pollutin sensor light that came on, it aint gonna be the cat is it?
ArosaRacer
Wee man returns in a fL mk2 cupra
Aug 28, 2005
2,299
18
44
Bayview, Kent
22 pound in vw and depending on which one has gone pots 1and 2 2 mins tops 3 and 4 ten mins as you have to remove the vac resivor and n249 plus bracket with a 5 mm allen key and a 10mm nut
james walker
May 24, 2007
5,121
retford notts
whats the coil pack then?
i would like some info to take to the garage so they dont rip me off?
what other faults might it be?
cheers for the help matey
ArosaRacer
Aug 28, 2005
2,299
18
44
Bayview, Kent
coil sits on top of spark plug, take it to seat and ask for a coil pack, go in a sound like you know what it is or they will pull your pants down and abuse you!
james walker
May 24, 2007
5,121
retford notts
mate id let them abuse me if they got my baby sorted:wtf:
its going in to a garage down the road from me that do diagnostics, how long should it take them to fault read it.
are the coil packs easy to get hold of?
Punch IT!
you fool!
Jun 22, 2007
396
west london
Hiya i had a similar problem a few weeks ago but my light just stayed on didnt flash at me. I disconnected the battery and took off the engine cover to check for loose pipes. i found one pipe under the cover squashed flat and a coil pack on the far right sticking up so i pressed down on it which sorted that out and i puffed up the hose as best i could.
Reconnected the battery but the light came on still but then suddenly it disappeared never to return.
Dont know if this could work with you but worth a try!:shrug:
If not it will most propably be the coil packs.:think:
CupraUK
Pushing on
Aug 15, 2005
1,350
Bedfordshire
Its easy to work out which one has gone without diagnostics.
With the car running just start pulling them out one at a time. Hold onto the plastic at the top and point at the engine block. If it sparks and gives you a bit of a bolt, its fine.
When you find the one that will not spark, thats your dead one. With any luck it will be 1,2 or 3. That way you don't need to unbolt the thing that sits over 4.
I have them go every 6 months or so because I buy cheap old revision ones. I keep a spare in the car at all times.
PS: when replacing them, GENTLY push/pull the plastic tab back with a screwdriver before pulling the electrical connector off. Its easy to snap the tab
2,141
Mid Wales
nite then, does the car run really that rough with a coil pack going?
anyone else thats not sleeping.
The coilpack generates the potential for the spark plug to operate - if one has failed you'll only be running on three cylinders - that'll be why it's running so badly
james walker
May 24, 2007
5,121
retford notts
yeah its not under warranty, but ive had aa out and theyve diagnosed it as coil pack 4 cylinder nut running.
phew!!
in garage now, hopefully get done today as im at work but skiving now!
plus anyone that hasnt got aa warranty cover for 5.99 a month they cover repairs and labour upto 500 quid for a 25 quid excess, so its only gonna cost me 25 quid.
bonus
CupraUK
Pushing on
Aug 15, 2005
1,350
Bedfordshire
Get yourself a spare for next time (and there will be a next time) that way when the AA come out next they will do it for you there and then
