16v gti oil change
crezz
pedro motorsports
Jun 30, 2007
4,397
Woolacombe
isn't 10/40 the recomended use? repsol? according to castrol the 5/30 edge would be better then the 10/40.
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
using a pela is all well & good, but if you ever want to do it properly the sump plug will be well & truly stuck.
crezz
pedro motorsports
Jun 30, 2007
4,397
Woolacombe
since the mk2 was produced hasnt there been many new oils introduced since then so many might be better then what they recomended then?
crezz
pedro motorsports
Jun 30, 2007
4,397
Woolacombe
anyway, so i take the plastic under tray off and then ease out the sump plug. could also leave the plastic undertray off so the sump dosent get too hot.
Dec 17, 2006
1,837
Bristol
Castrol Magnatec has had a bit of a bashing, apparently it's a 'cracked' mineral oil and not a 'true' semi synthetic - whatever that means....!
Personally I've never had a problem with it, albeit on fairly short oil change intervals, 6000 miles or so.
However you can buy a good fully synthetic oil for less money than the Castrol 'Semi Synthetic' -4 litres of Fuchs Titan SuperSynth (how about that for a fancy name?!) for 17 quid in GSF
-Castrol normally costs 25 quid in Halfords!
The Fuchs oil was recommended by Opie Oils, who seem to be a fairly trusted oil supplier. They also recommended Motul as the top choice, but it's quite a lot more expensive.
Dolly_Gti
G60 spooling up.
Aug 15, 2006
1,412
china town
i used castrol GTX 10-40 semi sythentic because its free for me at work, the oil in my ibiza gets changed every 3-5k miles, the bimma has had 4 oil changes in as many weeks as it had been standard for ages, and now the Golf is due a service..
the perk of the trade ey
Boi Ninja
16 valves of sweet shhhhh
Dec 23, 2005
863
Enfield, Shanktown
...crezz MAKE SURE u dont round off the plug mate, mines ****ed ...still trying to work out a way to take the **** off ...its rounded grrr!!! garage quoted me something like £180 i think to take sump off and drill plug out and refit with a new plug. ...think ima invest ina pela pump as i got the garage to do it for me last time as i couldnt remove the plug. do all the deposits n crap get cleared up too?? or do they just stay at the bottom of the sump?
andyj
There's no F in Quality..
if you know anyone with a welder, just get them to weld the head of a bolt to the sump plug, and then just just a spanner to undo the bolt/sump-plug combo ;)
kiearn
156
Norwich
CREZZ, best to run the engine to get the oil a bit warm to begin with.
Once you have undone the sump plug and it starts to drain leave it for a good long while to drain before removing the filter. Make sure the oil filler cap is off as this will speed up the drain process.
WeeJase
pert
Jun 2, 2001
8,595
deposits worth worrying about,should be in your filter
