mathias.leon
I want to mount an in-car heater on the side of the tunnel below the centre console. The screws would be about where the black-and-yellow is. Are the any cables behind the plastic? How deep before hitting metal? Anything else that might be worth considering?
I'll post a pic of my car tomorrow.
edit: my car is left-hand driven.
just out of curiosity why are you fitting the heater?
what's wrong with the cars heater? mine warms up within minutes......but then it's petrol
:redface: hmm yeah you'er right there, doh:rolleyes:
Only by about -15/20 degrees or so......
Going for a trip? or moving? as your profile says you're in mid wales
I went to Finland for a few months on a student exchange program and it was -17 at one point, which wasn't as cold as it sounds strangely
lol Will he find oil?
no, there's nothing exciting there.
No worries then.
Although I live in the south of Sweden by the coast it's quite often the car looks like m0rk's Cordoba during the winter. A heater would let me drive away directly without having to get rid of the ice on the windows. And a warm car is nice :)
When it's -17 C the air is dry and it's usually not windy, hence the relative lack of feeling cold. A few above zero with lots of moist is much worse. Did you get the freezing-in-the-nose sensation? Quite odd first couple of times... Needs to be about -10 C.
wirnig for tcs and fuel release close but check firts. dont go any further forward though the airbag cu is about 30cm forward
Ooh :think:
I'd like the bracket to be as in the pic. Screws would penetrate about 9 mm from the outside of tunnel.
Here's the heater in place.
Really neat. Termini with 1350 Watts from DEFA. Only about 80 € and much smaller than any other heater. The cable runs out through the back door. Very pleased. :) Last night the out door temp was -2C but in the car probably +25C. :D
