Miltek exhaust
Importcupra
The Best Rev Hard
Nov 11, 2006
136
Hey Guys any 1 go any idears on how to stop the exhasut from vibrating?? it does it the whole time i drive the car and is driving me mad! thanks
cupra collins
216
Just find where its knocking and get urself under the car and adjust it iv got mine perfect now its a bit of trial and error but you get there in the end.
p34ch3y
tastefully modified
Oct 17, 2005
2,879
cambs
gunna get a blue flame turbo back in the new yr so il just have to put up with it till then
p34ch3y
tastefully modified
Oct 17, 2005
2,879
cambs
yea m8 im megga low at the back,
you cant pick it up that much it then hits the bumpper wich it pritty much is allready on mine at the mo.....:censored:
cupra collins
216
mines low at the back and it dont rattle at all not even on a long run with four people in the car
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Move the system forward until the hangers are pointing forward, it will give you alot more clearance over the rear beam. Not sure if this will still be the case once shes lowerd after xmas. I very much doubt it:(
Powerflex hangers help out quite abit too.
Importcupra
The Best Rev Hard
Nov 11, 2006
136
iv been under the car about 20 times tried to adjust it at work but still cnt, changed the rubbers. the back of my car is stupidly low, do u recon its so low that it just sits on the ream arms and cnt be helped. ( i know i could higher it but it looks good low lol )
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Like i said before you could try moving the system forward from the cat back, try and get it so you have the tailpipes pretty much flush with the bumper, When i done this i ended up with abot a 65mm gap between the pipe and the rear beam, admitidly im not lowerd yet but it could be worth a try.
Glassy80
HUZZAH!
Jul 24, 2007
265
Camberley, Surrey
Its rattling on the rear axel mate. Mine does the same thing when the car is cold, but once warmed up its fine. Take it to a decent exhaust place and they can supposedly sort it out easily enough. I've just not had time to do it yet, plus ive been thinking of replacing my standard one anyway.
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Sorry didnt read that you was lowerd:headhurt:
Thats abit of a bummer then, im hoping to lower mine around 60mm on the back with a miltek system :headhurt:
Welcome back knocking:cry:
