DUMP VALVE with whoosh, but without loosing power?
Empi5
Your scaring me.......
Feb 24, 2005
2,807
Staffordshire
I can honestly say the Forge Split R still makes me smile. Ive taken the sound deadening off and the noise is quite entertaining. Definitly a woooshhh and a tishhhhhh.
Running Revo Stage 2, Smoothed Air Box, 80mm feed. Its all down to personal taste.
Mar 26, 2007
2,020
S.Wales
is the stuff under the bonnet just for sound deadening? doesnt it serve some kind of heat shield type purpose? if its just sound deadening I might take it off and have a listen.... :)
caveo
yep just sound deadening and takin it off makes a hugh difference to the dv noise especially from inside the car i did it the other day and its sounds alot eeerrr (?) hollower if u catch my drift and def louder
caveo
plus it just clips off so u can put it stright back on if u want to ( mines still in boot just in case)
kernowcupra
had my forge 007 fitted and my green cotton induction kit done i get a quiet whoosh occasionally!
Skorchio
600 Miles to a tank :)
Jan 23, 2007
1,570
Nr Milton Keynes
IMO, it doesn't protect your bonnet from heat cracks once you remove it!
Good point the 1.8 20vt lump gets very hot!!
I might take mine off at the weekend :) i got the cold side recerc kit and it puts the DV right near then front grill :D so might not make huge difference to me
sparky22
i just put the BMC CDA on mine, hooked up with the spliter it sounds the nuts. essp when its only boosting up to 10psi after that its a bit quieter. Ive found tht you cant hear the spliter at full boost. I would say if your unsure if you want the spliter i wouldn't buy it only cos its about £130 alot of money if you deside you only want full re-cir. as far as i no the 007 is alot cheaper, but its your money matey ive been very happy with my spliter.
marky t
300 horse+
May 5, 2005
118
nth. lincolnshire
hi mate give aet turbo's in wakefield a call they do a turbosmart dual port dump valve with a re positioning kit i have one on my leon and it is seriously loud!!!
Seat til I die
Lap Record Holder
Oct 14, 2007
107
funny, i also got the forge dv 700p coupled with green cotton panel filter a couple of days ago.
can notice a slight but definite improvement in performance at certain points in the rev range, cant honestly say it sounds any louder at all, sounds slightly different i spose, cleaner, but the sound change is nominal at best.
good for me though, i didnt really want it to sound all loud anyway. well maybe a little bit louder ;) oh well, im happy!
drvince
212
The Netherlands
For better sound of the Forge Split-R :
No need to remove the sound deadening or buy a DV relocation kit etc.
Do as I did ,
I made a hose to run from the valve to the front...
Blows out from there through the grille, and sounds great !
caveo
Dont get me started on the split r valve mate. Be a clever boy and put it back to full recirc and feel how much smoother and faster your car is ( just go out and try it and get back to me , thank me later )
I too can post the same thing twice LOL!!!
drvince
212
The Netherlands
You mean putting the Split-R to recirc with the blanking plug ?
Or switch back to the DV007 ?
Avant4me
359
Bristol
Dump valve noise
Don't know what the problem is. I have a Forge 007P, but put on "the other way round" which Forge say is fine, basically the pressure is on the bottom of the piston rather than the side. That make a hell of a noise when i let off.
George S3
so what happened lol
does the splitter make you loose alot of power?
thanks
Lodgey180
WoOoOoOsShH
May 3, 2008
1,046
Middlesbrough
www.mootr.co.uk
ahhh i love these wooshy threads...
