got a cupra 02 plate, its got no changer just the standard head unit. whats cheaper buying a changer or ipod conecters and do thay fit?
can you control the skipping of the tracks from the dash though with any of these?
Wot about the xcarlnk? I've just bought one and it works great
Nick
I have dension icelink ipod connector, connects straight into head unit by removing the CD changer ISO socket.
Good points:
Quality is at its best doing it this way
Full control of ipod via head unit, i.e. you an skip tracks and select the 1st 5 playlists on ur ipod
It charges your ipod while connected
Bad points:
It seems a common fault is the fact you can't skip to the next track, it skips like every other track when ur browsing through. i.e, when on track 1, if you skip to next track, it will go to track 3, then 5, 7, 9 and so on.
Solution...skip to the next song, let it play for 4/5 seconds then skip to previous track. It skips to previous tracks fine.
Also, its very pricey. I paid £99, which is alot considering it has some pretty basic fundamental design faults.
Trust this helps.
