My car has failed its MOT on emissions. Apparently there are fault codes logged which indicate problems with the following components:-
Throttle valve pressure sensor - 058906283F (£152)
Front seat lateral sensor - 6Q090960600A (£214)
Does anyone know whether these would have any effect on emissions, as the dealer doesn't seem to have a clue if replacing these would fix the problem.
Related to this - my car had a starting problem recently and sometimes it would only start if you floored the accelerator. Could this have caused any damage to the engine or cat which would result in an emissions problem?
