Leon Tdi Only Goes Upto 90mph
Jav
CANB ANY! HELP ME. I HAVE A SEAT LEON 1.9 S TDI, THE CARS TURBO DOES NOT KICK IN UNTIL 2.5 REVS AND ALSO SOMETIMES IT DRAGS UNTIL U DO OVER 30. WHEN ON MOTORWAY AFTER 80 90 MPH IT WOND MOVE, N DROPS SPEEN UP HILLS. IF ANY1 KNO WAT THE PROBLEM IS CAN U PLZ EMAIL ME ON [email protected]
sheffboy
avoiding potholes
May 25, 2007
655
Jav. STOP SHOUTING FELLA.
Not quite sure what you mean when you say it drags until over 30 :confused:
where are you based mate?
Jav
hi m8. based in coventry. it feels lyke it strugggles to get to 30mph then the cars fine, its got all the poer i need. but on the motorways sometimes when i hit 80, it feels as if sumthing jus cuts out and wnt go past 80. som1 sed it mite be a air flow sensor
Jav
karlosR
TORQUEY, NOISEY V6
Mar 10, 2006
1,469
BEDFORD
try unplugging it to see if there is any improvement. it is quite a common issue and an easy fix................ its just annoying when it happens!
Smart22186
Newbie
Feb 21, 2006
353
Peterborough, England
same exact thing happend to me once, except i was driving at very excessive speeds on my way to stoke on trent at night (was in rush) cars ECU thought the turbo had fault as it was running full for about an 1.5 hours it switched into limp mode... scared **** outa me. felt like i'd run outa fule .. then realised that my turbo was being by-passed and that my company van was quicker than my car!!! any way never happend again ater that for me however maybe you do actually have a fault and your car switches to limp mode. whats it like after an engine switch off and on agian?
sssstew
Editing your spelling
unplug the MAF sensor, see how it goes. its a dead common problem so if you need help with that have a search back through the TDI section.
The only way to tell for sure is to get vag com on a laptop and log the MAF, if thats ok then i would log the boost. I presume you havent got loads of smoke coming out the back?
FR-RUSH
IBIZA FR TDI BLACK MAGIC
Dec 3, 2005
380
Islington
thats right that the turbo doesnt kick in untill 3000 revs, thats the case with all derv turbos isnt it?
you have to ride the turbo to get performance out of it.
im sure your local stealer would easly plug it in and tell you if there are any faults.
Molehill_Mike
Rollin' on 20s
Jan 3, 2005
2,566
Bedfordshire
1.8T blocks are different
002
010
115
and 118 are most commonly used with the 1.8Ts.... not 100% sure which is which, but out of those you have MAF, Timing, Intake Temps, and boost...
Mike
