brad1
hi there
i can get hold of a set of brembos for the front which came off a fiat 20v turbo. just wondering if these would fit a tdi leon
cheers guys
Don't see any reason why not, you may have to custom fabricate a mounting plate, the disc may not be too easy to find, jusst find out the width if disc you need and match it up to the size, shouldn't be too hard!
these arent like ours or the boxsters afaik in that where ours require a mounting bracket, it is built into the casting on the fiats, which i think is more of a hindrance than a help. hole centres , etc and offset are very unlikely to be even close to ours.
A bit off topic but when I was at the Pod last weekend a guy was running a FMIC from a Merc Sprinter van with his 20VT engine in a mk3 Golf.
Obviously some trick bits on those vans :)
sprinter ic is the ic of choice on any turbo mk2 golf conversion, it fits that tightly between the chassis legs, i dont think the plastic end caps can blow off!!!
Anythin can be done, one of the guys i know is running, Seat Cupra R calipers on Merc Sprinter van discs on an FTO!
point is lug mount is specific to model, radial mount is fitting via brkt, which is why its easier to adapt to other models
