Saturdays activites involved doing the wheel alignment.
Here is where the alignment was before adjustment.
after taking advice from several people, who said between 1 and 1.5 degree negative camber on front, i decided to go somewhere in between. so i decided around the 1.15 negative. Along with a little toe out as advised.
You can see here, the wheel clearly has negative camber.
So i took it for a drive, and..................... its bloody awful, steering feels lighter, and response is slow. So back to drawing board as far as settings go.
I might take it back to Cupra R standard settings and work from there.
Comments welcome.
