Mine's a Blitz Sus Power! Sounds throaty and doesn't need cleaning! Brilliant!
Okay guys Ramair max flow is about £109 plus delivery on ebay and this includes all pipes and feeds i believe? But on the Ramair website it is free delivery and only 90 quid i think for the cupra one, does that include all the pipes and feeds as well?? If so that has to be worth it?
I've tried out many different induction kits - recently I've swapped between a BMC CDA and a K&N cone filter tucked down the side of the battery with a 76mm pipe leading up to the MAF ... my car definately pulls harder with the K&N cone filter. I've been monitoring the intake temps too (using the Scangauge) and open or closed intakes are irrelevant, it's the intercooler that cools the charge air, not an enclosed filter. My intake temps remain the same using an open cone filter - whatever filter you use air always exits the turbo at 120+ degrees and is cooled by the intercooler before entering the engine.
After trying all sorts of things, I have to agree 110% with Rob. A big open cone does the business. Proven with logs.
You should know How many maf have you been so far?
My 8000 mile standard air filter cartridge outflows a new green cotton panel filter by about 5g/sec. It also outflows a dynatwist too. I'm going to try a large open filter next.Just bought an LCR and it seems it's most likely had a remap and has a Forge 007 valve on it but a standard paper filter - am I likely to see any noticeable difference replacing the standard filter with a green cotton panel filter?
