Been reading a few old threads and came across one on wheel spacing on the LCR where people have put 10mm on the front and 15mm on the rear does this actually make any difference to the handling i know it will widen the track but is the difference noticable ie the car handles and grips better. Also i have found you can purchase these spacers from Forge and Badger do they also supply the long bolts for fitment.
Rikko
I've just today ordered a pair of H&R 10mm spacers for the rear (20mm total track widening) with longer bolts (genuine H&R bolts) from the TT
shop. They came to £91 including postage.
Didn't bother with locking nuts as I reckon they're more likely to throw the wheels off balance and its a b*gger to remove the plastic caps off the bolts anyway if you dont have the right tool.
I've recently done a full suspension upgrade (KW V2's, Powerflex bushes , Eibach ARB's and strut braces) and am hoping they do further improve stability and don't vibrate, though stability already seems much improved from the other mods.
Let you know when they're on!
BTW I thought the spacers that bolt to your hub and allow you to use your own bolts only apply to thicker spacers (20mm per side plus?) as slimmer spacers won't have enough meat to screw into ?
