Looks good, although the transition from the dummy baffle box to the main diameter looks on the sharp side. Earlier pictures seemed to show quite a bit of wrinkling on the inside of the bend, that one seems okay though.
What's the OD, do the stock clamps fit? Not they'll match. The stock ones are stainless, if you fancy polishing them to match.
N75 outlet seems to be at a "funny" angle, should be okay though (as long as it doesn't hit the engine cover).
Does it have a little "pip" on the underside, about half way between the DV Outlet and the bend?
When you're swapping them over, be careful to have a quick check inside the stock turbo outlet hose (the red one) for splits/cracks.
Be careful not to overtighten the Hose clip on the N75 (you will need new), in fact consider running it without a hose clip. Position the DV hose clip before you bolt the whole thing down.
You can get the old one off if you have a strut brace, but if you're precious, stick a rag between it and the baffle box when you pull it off, and definietely put one in when you're fitting the new as it'l stratch like a bugger.
