Gave In.. N249 Bypass Done...My View
gp1
GUYS LOOK AT THE OTHER PICS ON HERE,LOOKS YOUR ONE WAY VALVE IS WRONG WAY,HENCE NO BOOST????? SURE SHOULD BE WHITE PART HEADING UP WARDS(POINTING TO THE BULKHEAD :doh:
Molehill_Mike
Rollin' on 20s
Jan 3, 2005
2,566
Bedfordshire
Shouting in your first post? Hhmmm.... :think:
I need to do the resistor bypass on the IHI, tidy it up alot more.... is that infor within these 12 pages??
I know its my thread, but its gone on and on and on and on.... lol
Mike
Nov 2, 2004
9,335
South Wales
Resistor is easy. 330watt 10hm, cut off the solenoids if theyre not being used any more and solder in their place the resistors. Simple.
Nov 2, 2004
9,335
South Wales
Dave, had a quick look and i cant find anything really.
I'm sure i have some spare resistors i'll see if i can find them.
You could always make a bank up of 110 watt ones.
craig_cupra
ive in the process off fitting a forge split r dump valve so whilst im on im gunna do the n249 bypass aswell. i was just wondering if any tee pieces or y pieces are needed? and if so where can i get one from? cheers lads
Beaker™
Slightly Unhinged........
Nov 21, 2005
1,900
C:\UK\Glos
I cant remember if you need an extra t-piece or not, but.... i've found that most Halfords stock t-pieces amongst their washer bottle pump/tubing section.
craig_cupra
fitted my split r and the dump dint seem to loud then did the n249 bypass and it deffo seems to have improved the dump noise. also i seem to have gained about 2psi. also would it be worth me getting a cold side relocation kit for my dump valve? cheers
Myki da Pyki
Senior Member
Jul 15, 2007
3,302
Bristol
www.facebook.com
My N112 valves broke off and started melting on the manifold. Managed to save the one i actually still use but the other was fried lol, so only have 1 connected and no engine management lights are up or anything like that which i thought would be. Welded the remaining N112 to a new bracket which wont fall off now.
Do i need to get a resistor to keep the engine management happy now?
ian_cupra
which one is melted?? you'll need a resistor yes
is it the one with the vac hose on it still??
