they are identical to look at. just about 30mm longer!
why wouldnt they fit? as you can see they just throw camber out!?
HoocH
think about it...
30mm wider so..... other parts are over extended 30mm also... driveshafts?
HoocH
also having no luck with the engine problems!!! found a boost leak so that smoothd out the idle but still running rough and lots of backfiring!?
even with a different n75
can someone confirm 100% the n75 connections please!? im sure its right now tho
HoocH
but i think the centre of hub is in same place, top of hub is closer in arch and bottom is further out! or am i looking at it wrong?
think about it...
