fitting a different stereo
Deleted member 20482
does this work the same for a sony wiring loom..
i have 2 blues and a blue with white stripe..
1 has "att" on it which i think is the phone lead (light blue)
1 has "amp rem max 0.3a" (blue /white stripe)
and the last one is connected from the sony connection to the black iso connector.(dark blue)
often wondered why sig was crap
5imonharri5
schweet schweet CANDY!
Aug 20, 2006
85
if i remember, on the car loom, the blues are remote live switch on, eg for the external sub amps or T.V. or anything else that needs a signal to turn on. Blue and white is for the speed variable auto volume adjustment.
Think its right, someone will either confirm or deny my knowledge. good luck.
I think the sony wires are backwards, or I may be reading the post wrong
att - telephone mute
amp rem max 0.3a - remote switch on, tells the auxilliary that the radio needs it to turn on.
Hope this helps, hope i'm right!
Shez
Where do you get these aerial amps from? gunna fit my Alpine 'cos I'm fed up at looking at the bog standard HU!
Anyone got any pics they can post so I know what I'm looking for?
dmmsta
Sold car - bought bike
Feb 10, 2007
787
Maidstone - Kent
You'll need one of these:
I got mine from Halfords, about 5-10 quid IIRC.
Works a treat on my Alpine.
m.r.davies
God's Property
Jun 13, 2006
608
Cardiff
are there any alternatives to scotch clip connectors? i used these years ago, but weren't the most solid
i want an easy way to connect various wires like this blue aerial amp one, without stripping wires and etc
