Do you push the button?
Do you?
  • Total voters
    30
jamiepyrite
147
So, I spent 2 years working in a mcdonalds store (I'm free now though!) and worked on the drive thru alot. What I noticed was that about 80% of drivers simply pulled their handbrakes up without using the button! I know this does damage to your handbrake and it's no harder to push the button in while pulling up!
So, do you mk2 ibiza drivers push or not? :)
WeeJase
pert
Jun 2, 2001
8,595
my mrs used to yank it up hard without pressing the button,then had two use to hands to release it.
pick the innuendo out of that one :D
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
I was told by many people that it does.. Any proof on your theory? :)
I did it everytime I drove all of my cars, and that'd be about 500k by now. and they've never failled on me
I've also taken 3 to bits, and they're fine too.
any theory on yours? or just hearsay?
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
well yeah, it's not like you pull it like a ripcord on a lawn mower.
2 or three ratchets for a well adjusted HB.
your driving instructor will have told you to hold the button in, because it will grate on the examiners mind. that's all
Gm8
Jun 13, 2007
661
Glasgow
i cant see it being bad at all , I mean u search ebay , look at all the cars and all the 'bad points' and find just one that says ' handbrake not working due to non-button pressing'
jamiepyrite
147
Just hearsay mate. Would have thought it'd wear the ratchets down though. Guess it's a myth until properly proven..
Someone contact mythbusters :D
But yes, the noise is one of those that grinds on me.. I hate it!
Boi Ninja
16 valves of sweet shhhhh
Dec 23, 2005
863
Enfield, Shanktown
lol ur a funny guy,
i do both bit of this n bit of that ...depends on my mood, and if i can be botherd
GrayT
I'm Old
Jul 7, 2004
812
London
Maybe it is all a myth, but most driving instructors and certainly advanced driving instructors say don't ratchet the handbrake. I know that doesn't necessarily mean there's a sound mechanical reason for it but surely any steps we take to reduce wear is good (ie why brakes are the recommended means of slowing rather than going through the gears?).
MarkW
Chris
Apr 4, 2007
210
Edingburgh
It does do damage to the ratchet, well, on my first car it did...
A 1989 1.3 Polo Squareback. Had a lot of this abuse in its life and the ratchet mechanism was only aluminium. By the time I got it, had taken its toll so much you could pull it up and tap it down again with the button out where the teeth were so worn away.
It failed its first MOT in my hands :(
gregclarks
Trying to Resist ARBs
May 31, 2006
314
its just a ratchet, no way does it damage it - take the leather gaiter off and have a look its 6mm steel! - its designed to be a ratchet, it just sounds horrible
ZBOYD
Looking up at the stars!
May 19, 2001
9,468
15
Cheshire
www.seatcupra.net
Exactly its a ratchet, its engineered to be a ratchet and do the job of a ratchet. :)
I'd say if people are pulling them up too hard they are just stretching the cables so making the handbrake perform badly. The ratchet lets you know in some way how much its pulled, 3 or 4 clicks should be ample in most situations. Any more and you need to have a look at the handbrake, it either needs to be adjusted or repaired.
